Solar powered motorhome question.
You can read the MIT and other university web sites for this kind of stuff as well.
When the product goes commercial and is actually used in other than an extremely controlled environment for a selected audience it means something - this is PR chatter probably looking for suckers for more funding. The fact they list a Cleantechnica article for PR says a lot about the company and none of it good - I firmly believe they post articles for pay.[SIGPIC][/SIGPIC]Comment
When the product goes commercial and is actually used in other than an extremely controlled environment for a selected audience it means something - this is PR chatter probably looking for suckers for more funding. The fact they list a Cleantechnica article for PR says a lot about the company and none of it good - I firmly believe they post articles for pay.Comment
4-6-8k$ should get >adequat system but still may have to suplament with generater/grid charge based on amount of sun.
*caveats abound!!!Comment
nternal the only way you are going to get electric heat in an RV is to park it at an RV park and plug into the grid.
Lights are no problem using solar in an RV. Refrigeration is going to be a challenge but possible and will need a generator as backup. For heat and cooking you are going to need LPG.MSEE, PEComment
A refrigerator is running much of the time at (usually) fairly low amps. 12 volt cooking does use more amps but for a lot of things the total power used is little (20-50 watt hours for a meal for one or two). Cooking with 12 volt and LiFePo4 batteries does make sense and even with AGM batteries can be ok. Of course for cooking things that take a while, it makes a bit less sense though still may be doable.
As for heating, I wonder how one of those small low powered 12 volt heaters would go plugged directly into a solar panel? They are little more than demisters, but if you got a 120 watt heater and plugged it into a 12 volt 180 watt solar panel it may well be enough during the day for a few hours at least.
Again though for heating unless you had LOTS of battery even an almost useless 150 watt heater for 8 hours is going to need 200 amp hours of battery...doable but a waste compared to propane.Comment
Microwave can be done, but microwave cooked food really suks. They are great for popcorn, steaming veggies, and reheating coffee but that is about it.MSEE, PEComment
I use a 12 volt frypan with a small AH AGM battery (but will use a LiFePo4 motorcycle battery soon for better handling of 10 to 15 amps and more usable power for the capacity plus lighter weight) charged from a 50 watt panel. Works great for ME but then I do not cook things that take too long.Comment
As for heating, I wonder how one of those small low powered 12 volt heaters would go plugged directly into a solar panel? They are little more than demisters, but if you got a 120 watt heater and plugged it into a 12 volt 180 watt solar panel it may well be enough during the day for a few hours at least.Comment
for the most part skylights are a net loss. Too much loss vs gain during heating season and way too much gain during cooling season.NABCEP certified Technical Sales Professional
A good double pane window will retain most of the heat. Or just block it off with a piece of styrofoam.
He was talking about heat during the day anyway. Direct solar is always better than solar PV -> electric power -> electric heat.Comment
Moveable insulation works. it's a PITA but it works.
In an RV during the winter when heat is needed however not so much. Remember the roof of an RV is generally flat so the angle of incidence is high meaning little heat and lots of loss. Summer is the reverse, although some sun control on the exterior would help. An operating light would be better to vent excess heat from the top.NABCEP certified Technical Sales Professional
Actually no. I'm looking to meet minimum survival requirements and one doesn't just need to survive during the day. Clearly one needs a way to store energy for this and, even more clearly, it seems it can't really be done with current technology.Comment
