I have considerable experience with new stuff - I have a few patents in my name and my name as one of the et all on others. All related to the iron ore direct reduction field. We did things in the plant when the technology supplier was still discussing whether it would work or not. Sometimes it works out and sometimes it is a flop.
A lot of things that can be cost effective in the states are either not available here or overly costly. Competition is a wonderful thing! Wish we had more of it!
I would now prefer the VRV (what multiple outlets with one compressor are called here) for flexibility, cost of operation and simplicity. With the water to air heat pump (5 ton) there is a minimum water flow through the unit - there should be a control valve and a recycle to short circuit the hot water (I run my water temperature at 38
Meanwhile, if you show up on PhotoNet and ask for free photographic advice, I'm likely to give it to you -- probably for the same reason you're here giving advice to me. And then we'll both seek out our own DIY solutions. I guess that's how it all works in this awful economy. (Here's hoping for better times ahead...)
