Small system to power freezer and refridgerator
From what I read you do not need solar. Be realistic, and set obtainable goals?
How many days of backup do you really need?
1, 2, 3, 4... What?MSEE, PEComment
Mosr of the chest freezers I have seen (Kenmore included) will cool through the front wall, so adding insulation there will not decrease, but increase you power consumption. What you CAN do, is get a sheet of the foil covered insulating from like mentioned above, and put in on the lid. The lid is the least insulated part of most freezers, and they do not dissipate heat through it. Also, this will help if you have your unit near a window, where it will be in the sun.
You may also want to check into converting a chest freezer into a fridge, and throw out you stand up unit. I recently put a fridge and freezer of solar, and ended up converting a chest freezer to a fridge to replace my stand-up. My stand up was taking about 3.2Kwh per day. My chest fridge, (which is bigger) takes about .5Kwh per day. Definantly enough diffrence to be worth it. Not all your dearly paid for cold air falls out of your fridge every time you open it for a drink... Also, the wieght of the lid helps keep a tight seal, and as a basic rule, freezers will always have much better insulation than fridges.Comment
None
You would Grow it, and Slaughter it!Comment
Then you'd find our house an absolute riot, Russ....Comment
Now you are not talking about the 1% but the .01%.
Be prepared for lots of company if such a thing ever happens - you will find relatives and friends that you can't remember - thousands of them!
Beautiful place!
How would I define ahead? No debts and a decent balance, comfortable retirement with the slow life of a village (where I live) and the city (35 km away).
I spent many years in dumps around the world working on projects - now is my time to enjoy![SIGPIC][/SIGPIC]Comment
TnAndy... awesome place... breathtaking buddy...
all it takes is imagination imo... i'm humbled from what you have done on your home. sustainability to the nth degree... the only thing missing from your place is a name
maybe "Tangani-lah"
Beautiful place!
LOLComment
