Hi..trying to decide between FM80 and Midnite Classic 150..Installation will be in Philippines so i need something reliable..Anyone have experience with either one of these controllers? thks
Outback FM80 versus Midnite Classic 150
I've heard the Classic is newer, easier for DIY replacements of fan, PCB's and firmware updatesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I like the Midnight Solar if you can afford it, especially the 250 model as you can really run up the voltage and power.MSEE, PEComment
My opinion doesn't matter. But it appears the out back handles more amperage. More use of strings per combiner.Comment
How so Vinny? I am looking at the Classic 150 volt model right now for 48 volt battery and it is slightly better than Outback depending on what PV voltage you run. If operated at 90 volts PV panel wattage maximum is 5202 watts @ 83 amps output to batteries, vs 4000 watt max input at 48 volt battery for the Outback. I see that as 20% gain. Operated at 12 volts is 96 amps which is quite significantly higher than the FM80.
I was so impressed with the unit I arranged at the conference a couple of weeks ago to get a demo unit to play with for a couple of weeks.MSEE, PEComment
Voltage.. Yes. The midnight solar handles more voltage hands down.How so Vinny? I am looking at the Classic 150 volt model right now for 48 volt battery and it is slightly better than Outback depending on what PV voltage you run. If operated at 90 volts PV panel wattage maximum is 52022 watts @ 83 amps output to batteries, vs 4000 watt max input at 48 volt battery for the Outback. I see that as 20% gain. Operated at 12 volts is 96 amps which is quite significantly higher than the FM80.
However.. Now I may of skimmed through this to fast looking at amp specs but the outback handles a tad more.
I would say it is better for what type of panel is being used for that MPPT. In my case the suntech at a little over 7 amps per string when combined worked better for the outback than the midnight solar.
It was also based on comparison cost. The midnight solar may offer 20% more wattage, I also found it to be a little more pricey than the out back. It seems that for what is paid for in watts is relative to cost.Comment
1) ****
2) Outback needs a MATE to do much adjusting other than voltage set. Midnight does not.
3) if you have long PV runs, other models of the classic, allow even higher PV string voltage, with only a slight reduction in delivered amps.Last edited by Mike90250; 11-06-2011, 10:41 PM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Vinny I think you need to read and compare the specs side by side in a little more depth as the Midnight Solar 150 unit outperforms Outback FM80 in every parameter.
You are correct the Midnight Solar is more expensive, no argument from me on that observation, but the Midnight Solar 150 yields more power input vs battery voltage (20%), great data logging capabilities included, can be paralleled, and has a lot more Bells and Whistles like Ethernet ready.
With that said I cannot recommend it yet to the OP because he is not in the USA, but would not hesitate to recommend it to any USA resident because warranty protection is a snap here with teeth and ease of claims. Time will tell, and if it stands up to time is a winner IMHO.
The one thing Midnight Solar does offer is up to 250 volt Voc panel input, and battery voltages up to 120 volts. Those are rare and offer a lot of advantages in residential/commercial/industrial applications. It is the first consumer rated product I have seen offered in those voltages. Otherwise you have to move up to commercial/industrial units to get that kind of voltage range and they are extremely expensive with a several thousand dollar price tag.MSEE, PEComment
Midnite solar recommendation
We just installed the Classic 150 and can recommend the model and the support from the company. The manufacturer helped us (over skype and email) with a wiring problem that was contrary to the users manuals' suggested use, and the Midnite compensates for a wire run of over 80 feet (4awg) from combiner box to unit with less than 2% line loss.Comment
My understanding is that the Midnite solar allowed us to wire out panels in series to push 120 volts out (at 20 amps) over the line. The MPPT (Maximum Power Point Tracking) allows perimeters to be set and constantly regulates input charge to the battery bank changing the ratio of volts to amps to be above the 25 volt battery system, but below the amp circuit breaker. Does that make sense?Comment
Yes but any MPPT controller can do that. The whole point of using a MPPT controller is so you can run the panels at high voltage to minimize line IR losses.My understanding is that the Midnite solar allowed us to wire out panels in series to push 120 volts out (at 20 amps) over the line. The MPPT (Maximum Power Point Tracking) allows perimeters to be set and constantly regulates input charge to the battery bank changing the ratio of volts to amps to be above the 25 volt battery system, but below the amp circuit breaker. Does that make sense?MSEE, PEComment
