I have a Schneider 48v conext off grid system and all #s look good but my GFI is blinking green. Batteries are at 50.0 with load on so I’m good there and I unplugged everything to test as well and reset again. Came right back on. Bad GFI? Thx for any help. rb
Bad GFI?
Suspect it is a bad GFCI. "...A green light should never flicker, but if it does, it's probably due to a faulty indicator light or a defective GFCI circuit"
Source: https://www.doityourself.com/stry/ho...-status-lights
Although I have replaced GFCI outlets on my own over the years, I am not a licensed electrician, did not play one on television, nor stayed at a Holiday Inn Express. Your mileage may vary.Rade Radosevich-Slay
Tiverton, RI -
I have tp agree with Rade. Sounds like a bad GFCI
