System randomly resets - battery or inverter?
  • bajabig10
    • Jun 2020
    • 4
    System: (9) Hanwa QPeak 330W panels in 3S3P, Epever Tracer 10420 150v charge controller, Sungoldpower 6000w 48v inverter, TechDirectClub 14kw 48V Nissan Leaf G2 battery pack (contains four separate 7-pack 48v modules).
    House is a vacation home with an off-grid setup down in Baja California.
    Two years ago (2019) I changed the electrical on the house from a 12v lead acid setup to what I listed above. The house does not get used June-September and someone is there maybe 10 days a month from Oct-May. System had been working fine during those two years.
    A month ago someone was at the house and the power was cycling every 20 minutes. When I say cycle, the whole house loses power for about a split second and then it comes back on. The main power draw is a full size refrigerator, LED 48" TV, and some LED lights and occasionally two ceiling fans. No big power draws like an a/c unit. I thought maybe one of the Leaf modules was bad so I came down to investigate. I have six spare Leaf modules, so I measured the voltage across all 28 modules and all were at 8.33v except five were 8.26v-8.27v. I moved modules around so three of the four packs had 8.33v modules across all seven and with the last pack I added five spares which were reading 7.77v to two 8.31v modules.
    Since I moved modules around and only had three of the four packs in use, the power resets now happen every 1.5 hours rather than every 20 minutes. I thought maybe the inverter was getting too hot so I have a floor fan blowing on it constantly, but it is still cycling. At night, it only cycled twice, once at 11pm and again around 6am.
    I'm trying to determine if I have a bad inverter or a bad battery. I talked to a sales rep at windandsolar.com and he said inverters either work or don't work and if I have a cycling issue, it is likely battery related.
    If all modules measure 8.33v that are in use, how can I tell if it's a battery issue? When a cycle happens and I measure all the modules, they all are at 8.33v.
    In the back of my mind, I wondered how long these used Leaf modules would actually last since they are used. The rest of the system is made of new parts. I thought measuring the voltage would help identify the problem but I've run out of ideas at this point. We spent $3k on the batteries and after talking with windandsolar.com, I'll need to spend $10k for an equivalent ~14kw Simpliphi Lithium setup.
    Is there any logging on the BMS that can tell you what the battery is doing ?
    With odd power factor loads, inverters can trip and reset with poor power factor, but 1 fridge on a 6kw inverter should be pretty safe.
    • bajabig10
      • Jun 2020
      • 4
      There may be logging but I don't have the equipment to read it. We bought it as an entire package and I didn't go through each module to test them before putting it to use.
      In general, do inverters tend to either work or not work? I think the issue lies with the batteries but was hoping others with experience would agree.
      • bajabig10
        • Jun 2020
        • 4
        I'm not sure if this helps, but here are a few photos of the setup.
          If those are the connections of the BMS, it's looking real nasty, like someone splattered spray foam all over? What is all that crud ?
          • bajabig10
            • Jun 2020
            • 4
            It's a product called QuickCote+. The house is right on the beach and it's to prevent corrosion.
              I still suspect the BMS is sensing something and shutting the battery down. Odd for an inverter to do that on it's own.
