Adding dissimilar panel string to existing install
I'm off the grid with a separate battery bank and one large split phase inverter.
so there are no individual inverters on the panels.
The fuse holders and fuses I was thinking about are marine(made for the elements) DIRECT CURRENT fuses for now. Since they are made for DC applications, it should address the arching gap brought up in a overloaded "blown" state.
I'm not opposed to ordering DC breaker boxes for long term.
I have understand current, but like the explanation of water pipes bottlenecking the flow of current.Comment
Good, it's much simpler with fewer parts.
it's not the fuses that arc, but it's the holder, you can't open them to check the fuses , with daylight on the panelsThe fuse holders and fuses I was thinking about are marine(made for the elements) DIRECT CURRENT fuses for now. Since they are made for DC applications, it should address the arching gap brought up in a overloaded "blown" state.
getting good gear works out better than getting wrong gear in the long runI'm not opposed to ordering DC breaker boxes for long term.
