Hi Everyone,
I have read through the other topics, and have concerns about by solar system I am planning for our shed bar. The plan as it stands it to have 300w of solar panel, through a solar controller to trickle charge 12v 200amp battery.
The lights through the bar will be powered directly from the load output on the controller, and there will also a be 4 240v sockets that will be used to occasionally charge mobile phones, run a laptop, or other low powered appliances. The main use of this 240v system is for a fridge that will require a fairly large inverter 1000-1500w, however this will only be for start up. When it is on it will only average 30w, but as it is compressor driven has a large draw for a split second on startup.
I have read the stickies on large inverters, on 12v systems, and wonder since our usage is going to be low in general does the same apply?
What are the alternatives?
Thanks
Martin
Thanks
Martin
