New System - Reviving AGM Batteries
  • Jesse.Bill
    • Sep 2017
    Hi,
    I am setting up a new system and am planning on using a set of 2V 800Ah AGM cells that I have been given which have been sitting for approx 12 months (if I can save them) They came out of a 48v System however, I am told only 22 of them are alive so, due to this and other factors I will be setting up a 24V system.
    So, I have 22 Cells of which I am hoping I can revive 12 of to make up the system and get some life out of... I am looking for some advice on whether or not I should charge and test the Cells individually before I go to the trouble of setting them up in the system. If so, how should I go about this process?
    Any info will be much appreciated.
    Thanks in advance
    Jesse
    Wow. You have to use a charger of some sort, likely a 40A automotive charger would do the trick. Wire 6 batteries in series, charge for 6 hours, and try the next 6. Keep a close eye on them any that start heating up, are likely nearing end of life. Do this is an area where if one blows, it wont ruin your kitchen cabinets. 6 hours won't fully charge them, but it will give you an indication of which will hold a charge. And calls that are much below 1.5V are likely duds, charge them slowly and carefully.
    So many ways this can go wrong, and only a few where it works out OK.
    • Jesse.Bill
      • Sep 2017
      Hi Mike, Thanks for your reply.
      Should I test the sitting voltage of the cells individually first and choose the ones with the highest voltages? or, choose the ones which have closest matching voltages?
        Match the resting voltages, likely the safest.
