Where do I stick this...
For future reference as a reference point I figure to share a failure on here so someone else won't repeat it...
In Olympic Peninsula area i.e. near Seattle with lack of light this set up does not work
Classic SL150 paired up to
Renogy 100w 12v panels 6 in series of 2 stringsThis set up will not power up the charge controller to get it out of resting mode on cloudy day in the middle of December. Will have to reconfigure to 3 in series to 4 strings, back to drawing board... BTW I'm at 24v system so I am over 130% the battery max voltage with either set up.Optimum Operating Voltage (Vmp): 17.9V Open-Circuit Voltage (Voc): 21.6V Optimum Operating Current (Imp): 5.72A Short-Circuit Current (Isc): 6.24A 1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
If the system worked on a sunny day it may well just be the lack of sun that is the problem.
Even if it were to power up the controller the amount of generation is likely to be minimal.
It's why I wrote this is cause this set up doesn't work with clouds as I believe the other way will or I will see if it will, though running out of time to hit the road for experimentation. Either way it will be good for charge controller not running so many volts.1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
Let's say I decide to go crazy and bump everything up to 48v on the batteries and everything that can run of them on 48v and just step down to 24v on stuff I can't find in 48v and 12v for stuff that can't be had in either voltage, would I lose more in efficiency stepping everything down than it's worth? How does everyone else or why does everyone else off grid run on 48v if there isn't anything that really runs straight off it? Are you guys on 48v just not running much DC and just converting it to AC?
Have hard enough time trying to step up to 24v on stuff in a RV, seems this country is in stone age on solar compared to other countries. Anyone just order stuff from foreign countries to work with 48 plus volts?
Unless it's a 1 room hermit cottage, trying to run 12VDC to properly rated switches and power outlets, and having 115VAC for the odd thing that you can't get in 12v, the cable lengths are too long, too much power is lost in the cable runs. Run a 48V bank, no DC appliances at all
Yep. Running a "regular" house, with plugs, outlets and county approved flush toilets. Fully half of my precious filtered water is used to rinse sewage down the drain.
Unless it's a 1 room hermit cottage, trying to run 12VDC to properly rated switches and power outlets, and having 115VAC for the odd thing that you can't get in 12v, the cable lengths are too long, too much power is lost in the cable runs. Run a 48V bank, no DC appliances at all1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
Forgive me if you know this already. Switching DC is different from switching AC. When you have long wires and DC, you can have serious arcing problems with mechanical switches. Even switches rated for DC may not last a long time if the power source is a long distance away, because the wire acts like an inductor, and when you try to disconnect continuous current, the inductor spikes the voltage up to try to maintain the current.
A simple RC snubber across the switch contacts will solve the problem. For higher current, you need a larger capacitor and larger resistor to safely dissipate the stored energy in the the long wire. It's easy for a 1A load, but for larger loads, the RC gets proportionately larger.
If this isn't clear or you need help selecting switches or snubbers, please ask more questions.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
If this isn't clear or you need help selecting switches or snubbers, please ask more questions.1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
Is that why you have the Midnite ePanel? I've noticed after reading history on the foundation of solar and inverter tech Midnite Solar was there through it all and who I mostly trust with right equipment. Like right now I have there master shutoff switch with their breakers and their charge controller.1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
i have the midnight e panel because it's a better piece of gear and more flexible than the Xantrex/Schneider ePanel. (lots more expansion options) Midnight also has the high voltage DC breakers and lots of the "right"goodies.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This link is a good engineering article on selecting the resistor and capacitor. If you really want to learn, this is good reading:
Even if you're not very familiar with resistors, capacitors and inductors, (V=IR, dV/dt=I/C, dI/dt=V/L), the artcle will be very helpful.
Disclaimer: This article was written by a capacitor maker to help people pick one of their capacitors. The same article applies even if you use a different brand of capacitor.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
Yeah I'm running their 150vdc breakers myself.1.2 kWh solar 10.56 kWh battery @ 24v in a RVComment
Snubbers for DC need to be designed/calculated for each load. Remember when cars had ignition points for the spark plugs? Those had a "condenser" in them and it was different for each car. Sure there were some "ball park" values, but the labor involved to carefully design a DC system is much more than using a proper inverter and "standard" wiring that all electricians know about.
