Looking for ideas on how to incorporate a generator in a large solar system.
Im not really concerned about roi. I have budgeted 50k for this project and 30k of that went to the grid tie system.Comment
You are not doing an AC coupled system. In an AC coupled system the bimodal inverter is the one that does all the real work for backup.
Now if you want to couple your system with a bimodal inverter like those from Outback and a 48V battery bank it will work fine. Though I think you need to consider a SMALLER backup system of just critical loads. If you want to run your welder off grid then start up the generator.
3 phase off grid equipment is substantially more expensive though. Your best bet there would be outback systems which can be stacked in 3 phase configurations. 3 Inverters, one per phase. or 6 ( two per phase) if you need more power.
The wright brothers invented not only a plane but the equipment needed to design a plane like a wind tunnel. You are trying to assemble something, not invent something. but are trying to use the off the shelf parts in ways that they are not only not intended but are not going to work.
I think you missed the part of the SE7600H not having a DC input for a battery. You can convert your generator output to 400V DC but the inverter is not going to like it and not going to communicate with it. The voltage is NOT a constant 400V, it fluctuates based on grid voltage as well as inverter capacity.
well off the shelf 48V systems are pretty common. what you are talking about is not only not common but will require a special permit for any battery over 48V ...This is true but now we are substantially increasing amperage loads and wire size both are costly in large solar systems. Also I want something that is easily reversed and can be reconnected to the grid because not many people will want to deal with a complex system.
I fail to see how that will help.
There is NO charge controller with a solarEdge system. The optimizers are directly attached to the PV modules and connected in series to the inverter. The inverter will not work without the optimizers.
It seems like you are trying to remove the optimizers,
and connected the PV modules in series to charge controllers (rapid shutdown code violation ),
the charge controllers to a bank of 400V batteries,
and the batteries to the PV input on the inverter.
None of this will work.
Do you even have a charge controller that can charge a 400V battery?
That is not how a bimodal (hybrid) AC coupled system works. You have to have a bimodal inverter that is LARGER than the grid tie inverter. So in your case you would need two 8kW bimodal inverters and large battery banks at 48V (that the bimodal inverters can use.)
Lots of people live in rural areas and have grid tie systems. It makes far more since for you to backup with a generator with your LARGE backup loads.
That would be nice if the grid was reliable. I live in a rural area not in the city. If power outages were a once and a while thing I would do like the rest of the mainstream solar systems.
In your opinion what would be a more plausible off grid solution given the energy requirements I listed in the original post?
But more so the entire plan will not work.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
These are two different goals.
The cheapest and most reliable way to get the lower cost energy is with a grid tie system.
The reliable power for your huge loads is best done with a generator.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Fair enough.
It looks like a grid tie system ac coupled battery backup is the best option.
Why is it not feasible to run the whole house off of an ac coupled battery backup? Not the whole property just the house.
If I use an ATS to power the main panel with battery backup would I be able to use an ATS between the solar edge inverter and generator to charge the batteries and run the house if there isn't enough solar production? There are times when the grid is off for several days due to poor weather conditions.
How much of a dc load is required to maintain the battery bank.Comment
Sure you could run just the house and would need atleast one bimodal inverter that is larger than one of your grid tie inverters.
Fair enough.
most bimodal inverters have multiple AC connections so that one is dedicated to the inverter
i am not sure what you mean by a DC load to maintain the battery.
There is generally no ned for any load on many backup systems. They sit waiting for an outage.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
From what I read online in ac coupling there is no way for the inverter to balance the battery packs and there was a need to have a dc consumer like a water heater to balance. I was going to use bmc to balance individual modules and use charge controllers to balance pack voltage. But I suppose that the bmc's would regulate the pack voltage by regulating modules.Comment
You are getting good advice here, stuff on this scale is not plug and play. The Wright
brothers became good engineers, developing their own launch system, gas engine,
and a high efficiency propellor.
The usual start point on these projects is compile just exactly how/where your energy
is being consumed. Getting rid of the obvious waste would be next. I am wondering
if air conditioning is much of it? The newest AC units can cut energy use to less than
half (as is happening here), and there are some units designed to operate DIRECTLY
from solar panels (grid backup). They will not do much under clouds, but that is not
when they are needed.
If the housekeeping stuff is under control, run the generator for welding or the well,
avoid all the issues of batteries. good luck, Bruce RoeComment
You seem to be mixing dump loads like a water heater and battery management.
there is no need for a dump load with a well configured AC coupled system as the bimodal inverter can regulate fully the grid tie inverter.
as for battery management, well that is on you 100% if you are building a custom battery bank.
Charge controllers do not balance you battery bank, the charge only.
also in an AC coupled system there are no charge controllers, they are only used in DC coupled systems.Last edited by ButchDeal; 10-25-2019, 11:54 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Thanks.
