I'm going to be hooking up a Rec-BMS and ordered a 50mv shunt from them.
My inverter can also use a shunt to measure current draw.
Can I hook both to the same shunt? The way I figure it, each device is just basically using an internal meter to measure the voltage differential. So would hooking two devices up to the same shunt cause a problem?
