(bought a book but still need help) I purchased 2 panels 200 watt (total 400) for my roof that gets sun all day with no interference. I plan on using 2 two hundred amp 6 volt deep cycle and one 750 deep cycle 12 volt for a 12 volt system. First of all does that sound about right and secondly what would be the maximum inverter I should get. I plan on splitting the system with a small amount of 12 volt led and the rest 120 volt led. Thanks for your help (batteries are at 100 %)
Need a little help with calculation ??
Hello,
You cannot mix the batteries of different capacities, and your should not connect them in parallel.
You woould need two separate charge controllers and panel arrays for each battery set.
You mention nothing about what charge controller do you have or plan having.
How big in Watts will your loads be?
I'll repost this handy battery chart I made up
Inverter size 12V would be 1Kw max, 24V = 2Kw, 48V as much as you need 'cause there is no larger
BatteryWattHourCapacity.jpgPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
