Hi all,
So I've been getting the components of my system purchased and reading up as much as I can. I've a couple of questions on best practice for low voltage disconnect that I'd appreciate anyone with experience weighing in on because I'm aware that the power to the charge controller should never be cut off while the PV array is continuing to feed power into it.
Since my last post I've currently got the following: Midnite Classic 200, 24/1200 Victron Phoenix Inverter and an ATS (MOES Dual Power Controller 50A https://amzn.to/32NZ2MZ ). This complements the 24V 100Ah AGM battery bank (the mppt and the inverter are the investment to cope with future expansion and I will not use the inverter anywhere near full capacity). My system is a back-up but I want to put it to work to supplement the power I'm using in the house without tying it to the grid. I'll try to give as much info as I can.
Firstly, the inverter has a low voltage disconnect which is adjustable, the factory default settings for it are;
"Low battery shut down (adjustable) 18.6"
"Low battery restart & alarm (adjustable) 21.8"
"Battery charged detect (adjustable) 28.0V"
"Zero-load power 9.5W"
"Default zero-load power in ECO mode (default search interval: 2.5sec, adjustable) 1.7W"
I currently don't know how to determine what voltage of my AGM 24V battery = what SOC, so I can set the voltages. Any info on that would also be appreciated as I'm looking to not go below 60% if I can help it.
The ATS has the inverter power running into it, the grid power going into it and also the battery power going into it. A low voltage disconnect can be set, so when the battery reaches a certain voltage it cuts the load, transferring from the inverter to the grid power. The ATS also has a voltage reconnect that can be adjusted where it will transfer the load again to the inverter. The drawback is that if the inverter turns off first, the ATS does not switch because it's the battery voltage that determines this.
So if the ATS kicks in, transferring from the inverter to the grid, I'd have the inverter drawing 9.5W or 1.7W if in ECO mode until a full shutdown at a voltage that I can specify. However, I'd still have the draw of the Midnite Classic (if anyone knows what this is I'd appreciate it). I believe the Midnite has some sort of low voltage protection, or a nighttime low power mode but I'm still trying to find exact details. Is there a way for it to break the PV array circuit and also power down automatically as the last fail-safe to protect the battery? If there is an alarm I guess I'm pretty sure I would be around to do it manually but auto never hurts if I happened to be out of the house.
Any insight or thoughts are much appreciated.
