OVERCURRENT Fault on Morning Star MPPT 60
  • SIF_PLC
    • Mar 2010
    • 10
    Dear Sir,
    My system configuration is 3200 Watts X 3 sets of solar panels, each is connected to Morning Star MPPT 60. And are connected to a single battery bank 200Ah x 4 batteries at 48VDC configurations.
    For last three days I have observed that OVERCURRENT Fault is logged in the table of each MPPT.
    Please advise, How can I get rid of this fault.
    Best regards
  • littleharbor
    • Jan 2016
    • 1998
    You have 180 amps charging a 200 amp hour battery?
      Are you looking at the MPPT-60 web page showing the logging ?
      That one fault code is poorly worded. It's a multi purpose for any fault, I see it often with my 3kw array on a 48v system too. Usually, on partly cloudy days, as sun pops out behind thick clouds, it can easily peak limit the amps for a minute till the panels warm back up.
      • SIF_PLC
        • Mar 2010
        • 10
        My battery bank is 12v200Ah x4 batteries connected in series to make 48VDC.
        Yes, I am checking the log on web page.
        Is this serious matter? If so please help me to sort this out.
        Best Regards
        • littleharbor
          • Jan 2016
          • 1998
          Why do you have almost 10,000 watts charging such a small battery? I'm surprised you haven't blown the tops right off the batteries.
          • SIF_PLC
            • Mar 2010
            • 10
            Dear Sir,
            My problem is we have loads on day time, but in night time we only have a load of approximately 300 watts.
            We need more power during day time.
            Waiting for the kind reply
            Best Regards
              Send a screen shot of the log page, I'll be able to tell if it's really bad or whatever
              see my attached screenshot. It's the current limit peaking, as clouds come and go.
              I will agree with littleharbor, your battery can be seriously damaged by high charging current. How long has this system been in operation ?
              • SIF_PLC
                • Mar 2010
                • 10
                Attached please find the screen shots.
                Yes for last few days it's cloudy weather here.
                Best Regards
                • SIF_PLC
                  • Mar 2010
                  • 10
                  Dear Sir,
                  All of these are over current faults.
                    None of your pics came through.
                    If you look at my screen shot, the Max Watts is right at the 3,000w zone, array voltage is way below max 150V. As clouds come and go, the panels cool and then when brightly illuminated, can exceed their nominal rating till they warm up
                    • Yet another Yeti
                      • Feb 2019
                      • 51
                      320 Watt panels * 10 in series ?
                      * 3 parallel ?
                      270+ Watt solar panels currently have around 9 A Isc * 30 Voc ...
                      The Impp might get reduced , and therefore this message gets printed
                      to the logfile .
                      ​​​​​​​Software-problem to print better "non-standard" conditions .
