And for wiring of two or more parallel batteries or stacks of batteries, see http://www.smartgauge.co.uk/batt_con.
You generally do want to charge through the same set of terminals that you discharge, just not the same position on both halves of a parallel set instead of diagonal wiring.
Wiring batteries 2volt to 24volt
Ditto what Butch saidIf you connected 12 - 2V batteries into a 12V bank then you have 6 in series paralleled to 6 more in series.
With that parallel set you should have two TWO sets of terminals that are reading 12V
2000Ah is a heck of a lot for a 24V system. If you can return or cancel that 24V inverter I would recommend doing so and getting a 48V inverter instead.
you will need 4 parallel strings with your batteries to get 24V but only 2 parallel strings to get 48V
Both systems will have the same power storage but the 48V one will be more efficient, use smaller wires and be safer overall.Leave a comment:
Hi everyone have just joined the forum so may be asking a question that already has been answered. I have just purchased 48 2volt 500amp batteries and would like to wire them into a 24volt 2000amp system . I have connected up 12 into a 12volt bank using a old 12v inverter while I am waiting for the new 24v one. What I am not sure about is that I only have 12v output from using one terminal of the first battery and the other off the opposite terminal on the last battery but I have been told I shouldn't be putting power in to the batteries and drawing it out from the same terminals but these 2 terminals are the only ones which are 12volt . If this is wrong would someone be able to help with a wiring diagram for 12 2volt system staying at 12volts with a power in and a power out connection points and also a wiring diagram for 48 2volt into a 24volt system with a power in and power out . Thank you for any help Regards Dave
