Hi, I've been running a small 1400w pressure washer off my system for a while now but last year the washer gave up so i bought a new one, the new one is a little bigger at 1700w, the inverter is a chinese 3000w with 6000w surge Modified sine wave but won't run the new washer, i was thinking i may need to up grade my system to a 24v and started to look into this when i found a few reviews on this 12v inverter
So decided to give one a try, however it's the same and just won't start the pressure washer although it does try unlike the other one i have.
I'm i expecting to much from my 12v system or is there an answer to my problem ?
My battery bank is 430 AH and was 90% charged at the time of testing all leads are heavy although the leads that come with the inverter were on the thin side but there was two for each terminal.
Just in case it makes a difference i'm in the UK so it's 240v AC, the pressure washer gets used every day for around 20-25min, the washer is not plugged into the inverter direct it's through an extension cord approx 45ft
Any help would be great.
Thanks you
john
Thanks you
john
