Battery bank draining fast
    Originally posted by morton.bia
    Well i guess i know where my tax return is going this year lol thanks for the help!
    any recommendations for a good mppt cc with wind support? I'll get 4 more panels so 1400wsolat +400w wind
    You will need 2 MPPT controlers, one for Solar, and one for wind. The only one I know supports wind, is the Midnight Classic. And it only supports the Charging. Once the battery is full, you need to either apply brakes to the turbine, or provide a 200% reliable dump load for it.
      Morton forget the wind turds. You do not need it. Stay away from Chi-Com electronics as they are counterfeits and fakes. Bite the bullet and buy a good quality MPPT Controller. Midnite Solar Classic is really good. Being in NV with good winter Sun Hours, 1200 watts is more than enough and you can get away with a Morningstar 60-Amp Tristar MPPT. At 24 volts will allow you to grow up to 1600 watts @ 24 volt battery or 3200 watts @ 48 volt battery.
      • thastinger
        • 804
        You could do all this for a good bit less money than SK is quoting.
        - look on Ebay for some used 250W(ish) panels, you can usually find them for about 80 each shipped (I paid 820 for 10 shipped to a local freight terminal just last month)
        - ditch the 24V setup and go to 48V, this will significantly decrease your battery costs, this way you can go with 8 of the 6V 225Ah batteries in series, batteries will last longer like this as well and will be more readily available if you have golf cart retailers in your area.
        - you could wire 5 of those panels in series with a midnite classic 200 CC
        My "starter set" of batteries was trojan T-605s, I got 5.5 years out if them and will replace them this weekend with T-105s. You won't have cores if you buy 6V so look for shops with lower core charges. Including the core charge, T-105s will probably cost you around 160 each.
        1150W, Midnite Classic 200, Cotek PSW, 8 T-605s
        • morton.bia
          • May 2018
          • 25
          Hmm correct me if I'm wrong but if I use 8 6v 225ah to make 48v wouldnt I have only 225ah at 48v? Which is 10800wh. If I got with 8 550ah 6v to make 24v I'll end up with 24v 1100ah which is 26400wh which is more than twice the capacity
            • 15179
            You are correct but you would be paying much more for a 550Ah then a 225Ah battery.
            • morton.bia
              • May 2018
              • 25
              Hmmm 550ah 6v rolls battery 339$, 225ah 6v 160$ (according to previous post) so almost same price if I want the higher capacity. How long would 11kw last me vs the 26kw? Is if simple division like 2600w a day equals to almost 4 days power on 225ah and about 10 days on the 550ah? Or is there more to consider on this calculation?
              • thastinger
                • 804
                You stated your loads were 2.6Kwh/day and your night loads were significantly less than in the day correct? Successful off-grid systems are typically designed for 3 days of no Sun with that only taking the battery bank to 50%, for the worst solar month of the year. IIRC you also said you were in NV? I assume that means you don't have many overcast days in a row? Not sure why in the world you would need a 26Kw battery bank when your loads are 2.6Kwh/day with most of that being in the daytime (according to what you have said). If you're planning to put up 1200W of panels you'll never properly charge a 26KW battery bank with that.
                The 160 for the T-105s was WITH the core charge, I assume the 339 for the rolls batteries is also WITH the core charge? If not, I struggle to see where twice the price is "nearly the same".
                • morton.bia
                  • May 2018
                  • 25
                  The 8 550ah 6v batteries numbers came from sunking who replied earlier
                  you are correct on the not many bad days in a row... except this last week that weve had close to sun for a good 10 days now lol generator usage is killing me lol
                  I see the t105 for 158$ or t105re for 178$. Even using them as 24v would make it way cheaper for sure
                  • morton.bia
                    • May 2018
                    • 25
                    Sunking would you mind explaining how you got to the 8 550ah 6v batteries? And why youd recomend that instead of the 225ah 6v ones? Just wanna have all info to be able to choose the best option
                    • thastinger
                      • 804
                      Not to speak for SK, but I'm pretty sure he called for the larger batteries because you initially said your loads were 8ishKwh/day
                      • littleharbor
                        • Jan 2016
                        • 1998
                        That and as a rule you want to keep your battery bank to as few strings as possible. Ultimately a single string when possible.
                        • morton.bia
                          • May 2018
                          • 25
                          So based on info here I want something that if I have no sun for 3 days I'll only drain batteries down to 50%. That means 2600w x 3 days x 2(for 50% margin) / 8batteries / 6v = 325ah batteries minimum
                          correct?
                          • thastinger
                            • 804
                            So based on info here I want something that if I have no sun for 3 days I'll only drain batteries down to 50%. That means 2600w x 3 days x 2(for 59% margin) / 8batteries / 6v = 325ah batteries minimum
                            correct?
                            No, I don't think so anyway. Yes there are losses in the system but 59% is for PWM charge controllers. Quality MPPT controllers are significantly better than that and quality inverters are north of 90%.
                            Experts feel free to chime in (she says her panels are 50 ft away, my thoughts are higher V and less A panel config)
                            - Trash everything you presently have (you'll save money in the long run by going 48V)
                            - 5 250W panels in series to a Midnite 200CC, (will let you run smaller wire to the CC)
                            - 8 T-105 batteries in series for 48V
                            - Cotek PSW 1500W 48V inverter
                            It is pretty rare that you actually get 3 consecutive days of 0 watts, even on very overcast days I usually get 100W in for at least a few hours from my 1.2KW array. I recommended Cotek and Midnite solely based on me running both and having zero issues with either in 6 continuous use years, there are several good quality components to select from but I would stick to UL listed components.
                            • morton.bia
                              • May 2018
                              • 25
                              Sry the 59% was a typo I meant 50% since you only want to run your batteries down to 50%
                                correct?
                                No. 5 days ends up being real expensive, and obtaining a backup generator to handle the cloudy days is much better.
