Here is my setup:
295 watt panel (32 Vmp)
15 amp MPPT charge controller
12 volt 150 ah FLA battery
Fuse block with Negative Bus
The setup will be stationary.
The house is off-grid so the system is stand-alone.
All loads will be 12 volt, I only plan on running a couple lights and a low power laptop.
Though, if possible, a 12 volt freezer to make ice once or twice a week during the sunny days.
The panel will be about 30 feet from the house.
If there is the possibility of a storm, the panel will be disconnected from the charge controller.
I've attached two pictures, one grounded and one floated.
Would the floated diagram work since the system is 12 volts?
Thanks for any help
Thanks for any help
