I finally found an A/C that will run on solar. For a little over $700 for the unit and 48V charge controller than it needs to run. Plus I should be able to use 4 of my solar panels to make it operate. And then I need 600 Ah worth of batteries for it, all wired in series for 48V. They said to order four 150 Ah batteries for it.
Need advice on "reasonably priced" 24V inverter
I finally found an A/C that will run on solar. For a little over $700 for the unit and 48V charge controller than it needs to run. Plus I should be able to use 4 of my solar panels to make it operate. And then I need 600 Ah worth of batteries for it, all wired in series for 48V. They said to order four 150 Ah batteries for it.Would that be 4, 48 volt, 150 ah batteries?? no such creature. If you were to find one it would weigh 400+ lbs. If you were to use 150 ah. 12 volt batteries then you would need 16 of them to achieve a 600 ah. @ 48 volt battery.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Here's the A/C unit. This price is for the hybrid that requires 220V or solar panels. The one I'm ordering is $509 and it's the off the grid version:
Plus I have to order their 48 volt inverter for $80. Plus shipping and freight forwarding. Then I still need the batteries which I can get from the same people or there are many others on there selling 150 Ah batteries as well.Comment
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
When in parallel voltage stays the same and current goes up. When in series voltage goes up and current stays the same...Comment
The company said I need at least four 12V 150 Ah batteries wired in series. That has to keep the A/C running for nearly 5 hours. I guess I could go with 200 Ah ones. Those would be huge in my master bedroom to run the A/C.Comment
Instead of batteries, how about freezing a lot of those (state change) freezer packs when the
sun is shining? Then blow air over them after sunset. Bruce RoeComment
After this A/C project, I would next like to see how I can easily charge my electric car.Comment
If the grid goes down for more than a few days, it's going to Mayhem, no one is going to be your friend - not even your friends. A few weeks ago, Stores in N. Central FL had a momentary black out and shoppers went wild and started looting. It will not take much.
So no one will thank you for being a whack job now - and trust me, I'm right there with you for the same reasons. But, no, if you have food and power, they will come after you. So You had better be loading up on guns and ammo too and be prepared to shoot and keep shooting. A world without the grid is a world most of us would probably not want to live in. (or at least would not be prepared to live in very long)285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4Comment
IMO if there is an extended grid outage having solar or emergency power may "draw the pests to the light". You will need a big bug zapper to keep them away.Comment
When I was a kid, some folks in my area, and I mean more than a few families, spent their summers in cottages around the Finger Lakes in upstate NY with no power at all, pretty much by choice and preference. They mostly had primary larger homes with utilities usually less than ~ 20 miles away, but pretty much locked them up for the summer. I remember the old folks at the time mostly decrying how soft society has become what with all these new fangled gadgets like TV, etc.Comment
I see the days before the grid as being mostly just dedicated to staying alive. You didn't last much longer
after getting too sick or old to play that game. Only a few had the luxury of thinking mostly of other things.
The idea of hauling my own water instead of that pump, or growing my own food instead of that monster
tractor across the street, cutting firewood and moving it along with taking care of the horses, is scary.
Bruce RoeComment
If I needed to harvest, buck, haul, cut, split and stack 2.5 cords of wood, just myself (62) and wife (67) we might last 1 summer. Instead we were wage slaves for 35 years, saved $ and can now hire firewood cut to the right length and delivered. We still stack it though. Oil lamps and candles at night eventually soot up the house. cooking over wood, that's all behind me. When propane can't be delivered, wood stops, and seeds are not available, then I'm in deep do-do.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If I needed to harvest, buck, haul, cut, split and stack 2.5 cords of wood, just myself (62) and wife (67) we might last 1 summer. Instead we were wage slaves for 35 years, saved $ and can now hire firewood cut to the right length and delivered. We still stack it though. Oil lamps and candles at night eventually soot up the house. cooking over wood, that's all behind me. When propane can't be delivered, wood stops, and seeds are not available, then I'm in deep do-do.Comment
Bruce RoeComment
