Seems like it's got the auto-restart spec you would want. Did you read the fine print:
Note: It is recommended to use stable DC power for the input power supply If you use the pulsed DC power provided by the generator, please filter it with capacitor before connecting it to the converter.
Generally, connecting to the battery terminals will be a pretty good "capacitor" and it will likely be OK. Use a fuse on both it's + input and + output wires, and size the wires to match the fuses you use. I'd suggest 30A for the input and 50A for the output.
30A needs 8ga
50A needs 6ag
wire gauge chart https://www.westmarine.com/WestAdvis...e-And-Ampacity Be sure your wire is rated for vibration, that's why I linked to a boating site, not a house site
30A needs 8ga
50A needs 6ag
