too much shade there to put panels up. You need NO SHADOWS from 9am - 4pm if you want a reasonable harvest
Beach cabana's solar set up
The whole property is old growth hardwood. Anyplace we put the panels will require chainsaw work, I would prefer on top of that cabana because it will take the least cutting. That brings me back to the previous question though.Comment
Well, you have a problem. They are solar panels, not shade panels. Shade on a panel, even the shadow of a rope on a sailboat, will reduce the power from the Whole panel. A little shade on a spot of a panel, reduces the whole panel a lot, not just the 3% of the shaded area. So you will have to put the panels up, over panel 300% and hope you get enough that things work. You need full sun 9am - 4, but I said that alreadyPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I have a chainsaw solution to the problem. As much as I hate to do it I will cut down whatever I need to. My plan was to put it on top of the cabana because that will require cutting down the fewest trees. I apologize if I wasn't clear about what I meant by 'cutting' and 'chainsaw work'.
Now, are the panels the aforementioned part that will need 'replaced every year'? Will placing them on top of the cabana help mitigate that? Do I need to carve out an inland opening instead? If so, how far away from the beach?Last edited by PalawanWolfe; 03-24-2018, 12:51 AM.Comment
As you know, salt water mist corrodes stuff quickly. The frames and mounting gear for the panels will suffer from the salt, but should last 3-5 years. Don't forget that mid-day clouds will interfere with your harvest too.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
It is the salt air and shade that will get you.IMG-a35b21758f33de1de1ed01bdf2f6518b-V.jpg
Which parts will fail every year? If it is the panels, will mounting them to the roof of the pictured cabana help or should we have the panels some distance inshore?
MSEE, PEComment
