Hello,
First winter here being off grid - things are going fairly well.
During bad days, with lots of snow and virtually no sun, I have to fire up the generator a bit (Kohler RESA 14 KW) to charge my batteries (Rolls S550, 6V/428Ah x 8, all in series).
If I know I'll get a few hours of sun, say 2 to 3, I usually fire up the generator until I see from the inverter amps are going down from charging. When the batteries are about 50 SOC, the inverter/charger (Conext XW 6848) generally pumps 65 amps in the batteries, slowing going down to 10 amps after a good 2 hours of run time. So when I see the current going down, I usually stop the generator and let the solar panels continue or even finish the absorb state, often even going into float for an hour or two during "ok days". Do you guys think it's a good strategy for good care of the batteries?
Also, how about in very continuous days - is it better to run the generator 2 hours straight for the whole day until the absorb state is reached (and a good hour into it) or would it be better to run the generator 1 hour in the morning and 1 hour at night to finish bulk charge and go into absorb?
Thanks!
Thanks!
