Hi guys n gals?
Im a total newbie at all this solar stuff to be fair but have got half an idea about most things. This post is just about making the existing solar setup run better for a while - I have another system in planning which i will go into in another thread.
I have a small house in France, NO mains electricity at all. We don't need masses of power running toasters and kettles etc.
Currently there are some LED lights, a 12v USB charging point for a phone, a Shoreline 12v Fridge and an inverter for when i want to use the 240v cooker.
The previous owner has the panels set up something like this -
6 x 80w Baird panels, wired in pairs each going to their OWN Sinsola PWM (junk) charge controllers, he has then linked each charge controller and the last one outputs to the batteries! (does this means that we are getting the same output as one pair of panels??)
Panel data:
PMP - 80W
VOC - 21.8V
IMP - 4.55A
Then its off to the batteries which are 4 x 110ah 12v leisure batteries wired in parallel which can't be charged by those panels in that configuration??
I have removed one of the batteries and suspect i might have to remove another.....
So here is my proposal to get this system running a bit better -
5 x panels running in series which would give me -
PMP - 400W
VOC - 109V
IMP - 4.55A
If I'm correct?
These would be running into a MorningStar Tristar TS45 then out to the batteries which i would probably cut down to 2 in parallel to give me 12v - 220ah....
This is just a temporary solution to making good the existing system so that it works the best it can. I know about getting better panels, controllers, batteries etc and I'm in the process of sourcing everything for that so will post a different thread about that system.
Look forward to hearing some advice.
Antony
Panel data:
PMP - 80W
VOC - 21.8V
IMP - 4.55A
PMP - 400W
VOC - 109V
IMP - 4.55A
If I'm correct?
Antony
