If you were to use an LiFePO4 (LFP) battery the minimum size battery for your 15kW of solar panels with 3 Midnites and your 12kW of inverter would be around 500Ah (27kWh). Cost would be somewhere around $10,400 plus $500 for a BMS.
If you were only going to be running lighting, fridge and freezer, computers etc at night I can't see that you would need much more than that.
The two LFP batteries I have installed are over four years old and still as good as new. There are a large number of other people on other forums with batteries around the same age that say the same thing. steveg has an LFP battery that is over 7 years old and reports the same thing. It is worth looking at his posts. I can't see any reason that an LFP battery that is properly looked after won't last well in excess of ten years.
One plus with LFP batteries is that unlike Lead Acid batteries it is OK to add capacity to them at a later date.
There is no regular maintenance. Only issue is that they have to balanced correctly as part of the commissioning process, correctly set up and have some sort of Battery Management System to make sure they are not damaged by being taken outside their safe operating zone.
Simon
BMS - Homemade Battery logger github.com/simat/BatteryMonitor
Latronics 4kW Inverter, homemade MPPT controller
Simon
