off grid wind and solar 4000 square feet house
    Originally posted by max2k
    I wonder how they heat up the place, seriously. I'm not buying BS about 'thermal mass' keeping them warm through the winter, all that concrete would lose heat in a matter of hours, not months. I also don't know if there were any people in the building- supposedly they were warming up the place with their bodies but that process has a lot of byproducts which are released into the air even if we ignore mismatch between # of ppl required to warm up the place this way. How did they go about filtering all that stale air or was it their internal garden taking care of that? One thing I found living in the moderately cold climate is you still need air exchange with outside if you want to make it through the winter and not be constantly sick with one respiratory infection or the other.
    Even though bastardized for B.S. reasons in the Lovins design, the idea behind the building is one that's been around for several thousand years. It's largely passive solar energy, or suntempered design.
    Buy the idea of thermal mass. It is not B.S. Making it cost effective may not be possible in every application, but it, or various iterations of the concept, do have their place, with most all of the residential applications being a lot shorter than seasonal.
    On your educational journey, take a stroll through the concepts of thermal mass and insulation and how they can compliment one another, as well as a good measure of building sealing while keeping indoor air quality in mind, and how those things can be used in ways to help produce a very energy efficient building.
    Think of the building as something of a thermal capacitor with a lot of Farad capacity and a goal of a low leakage rate.
    Aside from Amory Lovins being one of the con men I rail about and the building he came up with (with a lot of free help/labor from his disciples) as an environmental and engineering joke - the idea of growing bananas in the Rockies was actually an original design goal in when conceived in the early '80's - the idea of a suntempered, VERY well insulated and thermally massive building done in a regionally and environmentally appropriate combination of those features, if done correctly, can be produce a very comfortable design. Cost effectiveness is the bigger challenge.
    Basically, the idea is to have a design with a very large thermal time constant, or a large ratio of thermal mass to overall heat loss. Once the building heats up, it'll take a long time to cool down, and vice versa. If the heat loss is low enough and the climate is sunny, it's possible to supply a significant portion of the building heat load with fenestration, with the thermal mass helping to avoid interior overheating and also allowing the solar gain to reduce aux. heat addition requirements long after the sun sets.
    The idea of seasonal storage is similar, but for the most part much less practical. The reasonable and practical limit for a residential building time constant these days is probable about 50 hrs. or so. My solar magnum opus in the desert had a design time constant of ~ 170 hrs., but that was pushing the envelope. That design would have all code required HVAC, but not use it very often, and probably be mostly/entirely self sufficient for winter heating without daytime overheating.
    With respect to existing dwellings, I took the thermal time constant for an existing residence built in 1928 in Buffalo from about 6 hrs. up to about 16 hrs. by lowering the heat loss and adding a sunspace with pretty good moveable insulation that contained about 6,000 BTU/deg. F. of thermal mass coupled to the rest of the building through the HVAC system.
    As for body heat, depending on a lot of stuff, ASHRAE will tell you a body might kick off ~ 150-300 BTU/hr., depending on activity level, between sensible and latent (vapor) loading. Most of the time, unless the application is a theatre/auditorium/classroom, etc. that load is mostly ignored for residential heating/cooling applications.
    Indoor air quality however, needs additional consideration. Until fairly recently, maybe 10 years or so, it was close to impossible to get a building envelope so tight it would suffocate those inside. Today, it's possible, using newer techniques like Tyvek wrapping, very careful attention to sealing details, not to mention insulated concrete forms, to come up with a design that will reduce infiltration/exfiltration to levels low enough to require controlled air exchange. Unfortunately, most products made for that purpose are usually less than adequate to the task with more than a few products worse than nothing in that, besides being thermally inefficient, they quickly foul up and become breeding areas for stuff that gets transferred to the incoming air, but that's a side bar conversation.
  • peakbagger
    I realize its thread drift but a properly designed Passivhaus or even the home brew Green Building Advisor Pretty Good House can have very little external heating need even in very cold climates like northern NH and VT. I remember a person boasting of the minimal heat required in a Pasivhause project a couple of years ago, they had an air to air heat exchanger system that used forced draft fans and had small heaters on the indoor vents to temper the outside air after it had gone through a heat exchanger, turns out they excluded the electric heaters in the ducts when they calculated the heating load as the heaters were contributing most of the heat to the house. It was all fed from a net metered solar power but could have just of well been fed by a robust offgrid battery based system (with a standby generator conveniently hidden away in shed. The key with thermal mass is having it inside the insulation envelope. Most folks forget that and regret it. Most of these high efficiency homes get away with a very small woodstove or a minisplit for supplemental heat and they usually only use them after a sustained cold snap. Unfortunately unless the designer has their act together that same thermal mass can make the house a very unpleasant place to live in the summer.
  • cebury
    Banana air has immuno-stremgthening and curative properties as well as a builtin air freshening flavor.
  • max2k
    If any one gets there in the winter, I'd be interested in knowing if Lovins is still trying to grow bananas in Snowmass CO. A very practical application if there ever was one, I'll say.
    Originally posted by cebury
    They supposedly still live there and it is open for touring twice a week.
  • cebury
    Thank you. Not Lovins place.
    Originally posted by histeel
    Westcliffe colorado
  • peakbagger
    Good we can keep one person from jumping off the cliff . Unfortunately some other person wont even think about asking questions and end up with expensive education. Optimistic at best wind might work in 1 out a 100 sites. Most folks don't want to live where the wind is blowing enough consistently for wind turbine to make sense.
    It always bugs me that many utilities charge a big premium for underground. In my area we have a lot of trees and inevitably the trees grow up near the service and at some point a tree comes down on a wire and takes out the service which means an emergency call. My utility doesn't encourage it but if I dug the trench and installed the conduit they would pull a direct burial feeder through if for the same price as overhead. In an adjacent town they wont issue a electrical permit unless the line is buried.
  • histeel
    IMO, a wise choice. Where is that now not under consideration located ? Sure sounded like Lovins turkey.
    Westcliffe colorado
    Well after many hours of research i have determined it is not cost efficient for this active solar home due to the replacement of the entire system. I have definitely learned a lot about new battery Tech. and the way a system should be setup. I cant thank you guys enough this is probably the most informative forum i have read.my estimate is around 70 to replace the system and that is not going to work. I have come across another solar active home with a much better setup. I have not had the opportunity to visit this property yet but the setup is definitely an improvement. Good news is Grid power is at the end of the drive, bad news is my guess is about $10.00 a foot for overhead and even more for underground for a grid tie if needed. It is only me and the wife no furnace or AC.Heat is radiant floor and pellet and wood, with 10 k backup generac. I believe it also has some wind power also but i have not been impressed with the wind numbers yet. still lookin in colorado.
  • histeel
  • AzRoute66
    Golly Molly, avoid the house because it has an old outdated solar system? It also has some serious square footage and a lot of windows with a view. It probably is something we would all drool over if it was on grid. I think the two biggest things I would want to know is who/how many are going to live there and will they be full time living or more of a summer/vacation house or what?
    As peakbagger suggested, for off grid living you must become at least semi-expert on the system, if you don't embrace that stay away from an off-grid purchase. Period. Have them call you when there are power company trucks in the driveway.
    As Sunking suggested, you have a massive amount of leverage. You are buying a very large 'cabin' currently without modern electricity. At the very least use every ounce of that.
    What do you have? You have some poles with racks on them already planted. I suspect the wiring 'might' accommodate modern panels as the picture shows jumpering the old ones for either 12 or 6 volts, suggesting some good thick wires. You have a very good brand generator that may be long in the tooth.. You have a lot of roof. You have some turbines that might contribute. You have some battery bank cabling in good repair (probably).
    What do you need? Pretty much all of the components; inverter, panels, batteries, panels, the whole ball of wax. How much of that we can help you with but we would need a lot of info starting with you doing a real load list - and finding out if the grid power is even going to be an option. I don't know about you but I am not even going to use it for weekends without some big TVs, satellite receivers, computers with peripherals, a deep freezer, a stereo or two, a dishwasher, a garage door opener, maybe a security system, a half dozen ceiling fans, and a cartload of kitchen appliances, etc. in addition to what you listed. I am what I am.
    You, on the other hand may be itching for the true off-grid experience and just want to do it right. Whole different load list, whole different approach. Whole different schedule for doing laundry and running that pressure washer on the deck. Go to bed earlier because surfing the net on your battery bank makes you feel guilty... It needs to truly be a lifestyle choice.
    Either way, once you decide what you want, refine that list of what you could keep with a trusted electrician and have some fun with learning the process. Even if you don't buy this place, the next might need some solar enhancement.
    I have not determined how far grid power is that would determine if i would go into negotiations.It is nearby they are building a few other homes now. Time will tell you are correct no one is looking for an off grid house. Kinda lookin for a deal if i can pull in grid power now. I believe this would be a good candidate for a grid tie system, depends on how far you have to bring grid in. we will see what happens there are several other off grid homes in the area but it looks like there solar systems are more updated and capable of running the entire home.
    Reread Peakbagger's post. He speaks the truth.
    I'd avoid the house. The alternate energy systems that are installed are, in all likelihood, too intimately connected and interwoven with the building and its innards to either be modified, worked on or otherwise maintained without affecting other building systems. Such things as usually done back in the day are usually more than simply bolt on equipment that can easily be changed out.
    Suit yourself, but my suspicion is that, as Peakbagger notes or alludes, you'll find in a PITA in short order. NOMB, but why do you need 4,000 ft.^2 anyway ? Sure doesn't sound environmentally conscientious to me.
    This place sounds a lot like the home that Amory Lovins built in 1982 -1984 in Old Snowmass with a bunch of volunteer labor and donations. What a con/trainwreck. He's still running that con last time I checked, unless this is that same turkey. and he's trying to unload it.
  • histeel
    Like I said, Leverage and you have a whole lot of Leverage. When it comes down to it there is no market for a Off-Grid home. You eliminate just about all potential buyers. Take whatever they are asking, then discount what it will cost to have it removed and replaced with utility services. If no deal come back to it again in 6-months or a year, no one is going to buy it. Wait until they are ready to take a soaking with a huge loss.
