Only one generator can be running at a time, unless you have a pair of inverter generators with a bridge/sync cable.
Tiny solar off grid cabin Northern Michigan
It would have to be in series and even then you'd have trouble unless they were running at precisely the same speed.
Yes. If one generator is DC it can connect to the battery pack directly (provided voltages work out of course.) You may be able to use the Outback to step DOWN voltages if you want; it won't step up. Make sure you do not exceed the max charge rate on your battery.Q4. I know that Outback CC support two wire start generators, while the Magnum 4440 PAE support three start generators. Is it theoretically possible to take two generators, and connect them both to the system: a DC generator to the Outback CC and AC to the Magnum Inverter? Does it make sense to do so?Comment
jflorey2
Is this inaccurate then? http://www.hydrogenappliances.com/Parallelcharging.html
Attached FilesLast edited by tverdok; 05-09-2017, 02:33 PM.Comment
Yes. Your battery bank will quickly become unbalanced. You will either need an active balancer (which have problems of their own) or need to do a lot of equalize charging to rebalance the pack. And of course if you have the power to do lots of equalize charging you don't need the wind turbines.
BTW there are some very erroneous schematics on that page. I'd avoid it in the future.Comment
