Originally posted by moorerichard2
View Post
A 12volt battery system limits you on the size of your loads and total panel wattage to about 1000W with the largest MPPT CC at 80amps. If you need to enlarge your system it is better to go with a higher battery voltage at least 24V and up to 48V.
A 200Ah 12v battery is really very heavy and hard to move around if needed. Going with 2 x 6V 200Ah are easy to find and much easier to lift and move. They are probably also least costly then that one big 200Ah battery.
