this is my first solar system.
145w, 24v panel
two 12v gel 40ah each
pwm controller
pure sine inverter 300w.
To the inverter I have connected a stereo pair of unbalanced speakers and my laptop (macbook pro retina)
both are connected thru a power extension which ground is connected to my house electrical grounding, this helps greatly to the noise however I still get noise in the speakers and some erratic behavior in the mouse of my laptop, (which occurs every once in a while)
I guess I would like to find a solution that fix both problems, I've been told that the issue could be in the low impedance of my house grounding and since I'll take this system to the desert of Atacama I'll try and independent GND rod for the system, any advices on this?
Also I've been told that I should take an additive to put in the ground since this land is not very conductive.
best
145w, 24v panel
pwm controller
best
