SDaniels - you can do this without a generator and should. In an emergency grab some dry ice from the store as you suggested. It's only 50 summer days your working to address here. You just need to make sure you don't kill the batteries necessary to get the system going.
Can I assume you are already looking at Coolbot to turn the A/C into a cooler?
Make sure first and foremost you are super well sealed and super well insulated. Also make sure any staff knows that trips in and out of the cooler are to be limited.
Use mini-splits. Look for Panasonic 20 SEER ultra high efficiency. Regularly used in battery powered trailer conversions.
Learn about lithium battery and use it correctly/safely. This will be an investment (nowhere near $30k for all of this) of time to learn and dollars to figure out, but these batteries don't need to be topped off every day, can sit unused over the winter, etc. Plus no sulfuric acid around or hydrogen to vent.
As suggested, don't mess with 100W 12V or 24V panels. You want the standard higher voltage (and higher power density) panels paired with an MPPT charge controller capable of a relatively high input voltage. Then you need an inverter connected to the batteries capable of supplying the very low amperage of this split system with low start-up current. Do not skip fusing - batteries can dump a great deal of energy quickly.
If you don't have $5-8k to do this move on to another idea. If that is reasonable, consider making it worth someone's time to help you out.
Good luck and hope you are able to impress your wife!
