I have a few questions about a pending completion of a setup i am making consisting of 600W panels , 12 volt battery bank setup, charge controller and an inverter for AC.
This is for offgrid cabin. - the cabin has an existing portable generator setup with a grounding electrode thru the concrete (both in the basement) and a panel box upstairs leading to a few outlets and such.
The solar system will be completely separate from the generator and not tied together electrically.
So the questions are ; do i make a separate grounding rod ? And if so would i need to bond it to the generator system? Or can i just use generators existing grounding rod?
And for another curve, there is a water well pipe about 12-15ft from the generators ground rod. I do not believe the water system is tied to the generator's grounding rod. The pump for the well is old and has no ground that runs off a plug from the generator.
