Hi folks, although I've been consuming myself with reading up and down about solar I'd still like to get any opinions or feedback on this set up from some of the Pro's here on the forums...its a big investment so I'm looking for some warm and fuzzies since this is not my area of expertise.
A little background on the situation. We are building in an area with 5.5 to 6 sun hours year round, warm climate so no freezing batteries or snow covering the panels to worry about. Maybe the occasional tropical storm or hurricane but we can deal with those gaps with a small generator (question on that later). Cooking and dryer will be LP, No Air Conditioners, minimal appliances, etc...
The cost of getting power from the utility company to the house location is high, after taking into account tax incentives it will probably cost about $5000 more to put in this system vs the cost to get power to the site. Also the utilities are unreliable and their rates ate about 2-3 times higher than the US national average at currently around between 26 and 29 cents per kWh and they are talking about a 20-30% increase next year.... So I'm thinking this makes sense to make the investment in an off-grid system, but its still a big expense so again I'm just looking for some reassurance that I'm going down the right path. Also I feel as if I'm working with a reputable installer but I know what I don't know.
So this is the proposed set up not including things like the panel mounting hardware:
6.12KW System
18xPV module Solar World 340w
3xBattery:Lithium Ex-Energy 48V 240Ah battery pack and BMS
1xInverter Conext XW 6848
2xXantrex MPPT-60
1xConext ComBox - Communication and Monitoring Device
1xXW System Control Panel
1xCombiner Box Midnite Solar 12 circuits
1xBreaker DC 15A
8xBreaker DC 250A
1xBreaker DC 60A
8xMC4 Connector Single (Female + Male)
From what I've found these are the spec's on the battery packs:
Nominal voltage: 51.2V
Typical capacity: 240Ah
Max. charge current: 80A
Max. discharge current: 80A
Discharge cut-off voltage: 40V
Charging temperature: 0-45℃
Discharging temperature: -20-60℃
Saving temperature: -20-45℃
The recycle life: 1500times
I'm also looking for any advise on a small generator to pair with this to help with peak loads and battery charging if needed. Id like for the generator to be LP but other than that I'm open to suggestions. I'd assume I'd add in a Conext Automatic Generator switch as well.
Thanks in advance for the help!
6.12KW System
2xXantrex MPPT-60
1xBreaker DC 15A
8xBreaker DC 250A
1xBreaker DC 60A
