I am trying to find out why and how the capacity of deep-cycle batteries can be harmed when they don't get cycled any deeper than 10%. Do any of you folks have information, or terms and keywords I could use to research?
shallow cycling, deep-cycle batteries
The major battery mfgs have addressed this, and overall, it does slightly harm the battery, A single deep 50-60% discharged) cycle every couple months will help keep plate material active. Winter time, one or two would happen naturally, summer time, chose a time when good sun is forecast so the next day can recharge it all.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike, yeah, thanks,that is pretty much what I have so far from Rolls Surrette, and I will definitely take their advice. Still, I would love to find more info on the subject, and one or two terms to keyword would really help. Like, what is the chemical process, how severe is it at various high states of charge, what does a depth-of-discharge vs battery life curve look like between 10% and 0% discharge per cycle.The major battery mfgs have addressed this, and overall, it does slightly harm the battery, A single deep 50-60% discharged) cycle every couple months will help keep plate material active. Winter time, one or two would happen naturally, summer time, chose a time when good sun is forecast so the next day can recharge it all.Comment
Perhaps if Sunking sees this, he can respond, I work with NiFe batteries and have not kept all the way up to date with Pb or Li batteries. Generally the Mfg's have the real data for their batteries and warranty requirementsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Shallow cycling a deep-cycle battery results in uneven sulfation (the normal kind that happens when you discharge), leading to problems like hot spot clumps over time when you do decide to do a real discharge.
Usually an indicator that you bought too much battery, possibly in the hopes of turning a 4-5 year chemical life / cycle life into a magical 20 year telco battery with micro-discharges.
If you were to try this as an experiment, a deep-cycle would not be the way to go, and a starter-battery designed for shallower discharges might be an interesting experiment. Still, you have a chemical lifetime regardless of depth of discharge to deal with.
I would like to get the best life possible from my battery bank, but also our needs through out the year are extremely variable, so at times we shallow cycle.Last edited by carilchasens; 09-02-2016, 06:09 PM.
Those are the kind of questions I like. Someone who is willing to do their own work and look things up.
The words you are looking for is FORMAT and PRIME. Start your search here.Last edited by Sunking; 09-02-2016, 12:37 PM.MSEE, PEComment
And all I know is how to format a hard drive and prime a pump.Those are the kind of questions I like. Someone who is willing to do their own work and look things up.
The references I get with this are to the initial wearing-in phase of a deepcycle's life. So far I haven't found anything about the deterioration that specifically occurs in shallow cycles, and the process of reversing that harm by occasionally cycling deeper. Is there a word for the sulfation or whatever it is in shallow cycles?Those are the kind of questions I like. Someone who is willing to do their own work and look things up.
The words you are looking for is FORMAT and PRIME. Start your search here.Comment
Chronic shallow cycling results in stratification of electrolyte, insufficient charge time to dissolve sulfate crystals, and overall capacity loss Not necessarily a big problem as all that can be maintained to acceptable limits with more frequent Equalization Charge.
If you are only discharging 10% over night, your charger will not go into Current Limit aka BULK MODE. Instead going right into a Constant Voltage mode Absorb, then Float. The battery never receives full charge current, it just basically gets slowly Trickled charged which is fine, but does not stir up electrolyte much or have enough time to dissolve sulfate crystals.
Essentially you are just Float Charging the batteries which is the best method for charging batteries and extending Shelf Life. However the operating nature of Solar does not lend itself to Float Charging. So assuming you have the battery properly Formatted and the plates Formed, you can shallow cycle, but will have to EQ more frequently. It also indicates you have a very RARE DISEASE. called Batteryoutwazoo or your battery is too large.MSEE, PEComment
Thanks.We installed our Rolls S-550s this summer, so I assume they are still formatting. Until recently, they were going through bulk-absorb-float every day, although our use was quite light for the size of the bank. Does the full bulk-float-absorb (Midnite Classic) mean that there is no worry? This week, fall rain weather has made a respectable call on the batteries and northern winter is coming - we do need the capacity.
Totally ignorant question here... To prevent stratification, could you just stick your batteries in the back of the truck and drive around occasionally? I know it wouldn't be practical, I'm just curious about feasibility
Depends on your roads. The stratification based on electrolyte density is really resistant to mixing just by sloshing around. Gas bubbles, on the other hand, mix things very well.
Instead of driving them around in your truck you could outfit them with dip tubes and nitrogen bubblers. Not too practical though unless designed into the batteries at manufacture.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Hmm, I don't know, but not very practical since my batteries weigh 70kgs each!Comment
Can stratification be an issue for starting batteries? (letting my curiosity run a bit today :P)Comment
Hi Sunking, I'm thinking I must have oversized my battery bank a couple of years back. What lead me astray was that we only use things like the vacuum cleaner, washing machine, toaster, etc, when the sun is shining.Chronic shallow cycling results in stratification of electrolyte, insufficient charge time to dissolve sulfate crystals, and overall capacity loss Not necessarily a big problem as all that can be maintained to acceptable limits with more frequent Equalization Charge.
I have a 580ah battery bank which I calculated was about right to allow for 3 days autonomy using 80ahs a day, but that calculation did not take into account our frugal use of high wattage appliances.
In summer we seldom discharge to more than 20 - 30%, and in Winter we occasionally go down to nearly 50%, at which point I charge up with the genny.
I haven't seen a bulk charge occurring in two years, goes straight to absorb in the morning. Thanks to my cheap CC, it keeps trying to push a full absorb voltage (58V) into the batteries, even when they are fully charged, for the full two hours that has been set for absorb mode. That results in regular over voltage disconnects - in effect giving a "Bounce" charge, which I understand old CCs used to do.
Would that bounce charging be similar to equalising? I use AGM batteries so am not meant to perform regular equalisation charges.
When the CC goes into Float, everything works fine, no bounce and no disconnects.Comment
Depends on how they are used. Starting batteries (ab)used for PV can stratify.
In normal vehicle use they get sporadic fast charging and some gassing during normal use, as well as vibration.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
