EDIT* In case someone comes looking. I've found a few of them, but I'm not entirely sure if they're reliable or if they can reach 96v. I've attached a excel file with what I found. I've also attached a possible alternative which uses two mppts to charge a 72v battery bank. The same can be done for 96v
We're building a project that would involve the use of multiple solar panels. It's supposed to be of high efficiency, so we'll be using MPPTS. The batteries that we'll be charging with the panels are supposed reach values of up to 100 volts.
My question is whether there are MPPTs in the market that can reach that value(at least 96v). I've been searching everywhere and the highest I've seen is just 72v
I'm sorry if I made mistake, especially in the location of this thread. I'm new here
Edit*
We're making a solar powered car, so I think the best way to describe it is that it's a hybrid. It will be initially charged from an external source. The solar panels will just aid in extending the range it can travel by charging the batteries as it drives.
We're students from the Philippines, and the estimated kWh the motors alone will be 30kWh at maximum . That already took into account the recommended fudging. We'll be using 24 ETFE 50W solar panel
Edit*
