I sold my large 240v generator so for now I am limited to 13 charging amps from my SW4048 inverter using a small inverter generator. With everyday charging the amps from the generator charging obviously combine with amps from the MPPT charge controller. My CC is the Conext MPPT-60-150 and communicates with my inverter on the Xanbus network.
So I am hoping that if I run an equalization charge with the inverter using the generator that it will use any power coming from the MPPT charge controller to assist with the equalization charge, even though the CC is in float.
For example let's say the CC is in float but there is enough sun to produce 10 charging amps. Will I have 23 amps available for the equalization charge? (13a from generator through inverter plus 10a from CC).
EDIT: Thinking about this further the amps during equalization probably won't be more than 5a so I will need less than 400 watts of generator power (5a x 62v = 310 watts). Does this sound right?
Thanks.
Thanks.
