My 48v Schneider system is fully installed and working great. I have been told by a few here that I need to fuse both the positive and negative battery cables at the terminals even though the positive cable connects to a 250a breaker at the E-panel. Looking for opinions on whether battery terminal fuses are needed and if so what amperage. Pic of my equipment attached. I will fab some terminal covers to protect from dropping a wrench. Battery cables are 10' 4/0.
My batteries are not grounded but my Schneider CC has GFCI protection so essentially they are grounded unless the CC fuse blows. I have read the concerns about GFCI protection on solar CCs but for now I am leaving it that way.
So let's assume something happens and the GFCI fuse in my CC blows lifting the ground. By fusing both the positive and negative cables at the battery terminals I'm eliminating the fire danger, right?
My charge controller is fused in and out with 60a Midnight Solar 100% duty rated breakers.
Specs of my equipment are below. I'm thinking 125a Blue Seas fuses at both positive and negative terminals (next size up is 150a) but thought I would let the experts chime in. Thanks.
p.s: I can't figure out why Schneider requires a 250a breaker for the SW4048 inverter.
Inverter:
SW4048 maximum DC input: 105a
SW4048 maximum DC output: 45a
Charge Controller:
MPPT-60-150 maximum output: 60a
Inverter:
Charge Controller:
