In the sticky by Sunking, 'Solar off grid battery design' step 5 is:
5 DETERMINE BATTERY SIZE and VOLTAGE
· First determine battery Voltage. This is based on Panel Wattage
· 0 to 600 watts = 12 Volts or higher
· 601 to 2000 watts = 24 volts or higher
· 2001 to 5000 watts = 48 volts or higher
· 5001 watts and higher = Forget it or higher than 48 volts. You cannot afford it.
We have panels rated at 800W on what is a 12V battery bank, but we're willing to change since our batteries are due to be changed.
The skicky suggests 24v for 800W panel size. I'm just trying to understand 'why' a 24v system..? Or, put another way... What one loses if continuing to use a 12v system with 800W panels?
