Hi, I'm new to the forum and thought I would share my system build with you.
I will try to explain as much as I can
System details
Solar array- 12x Suntech stp-260 24V panels
Battery Bank- 16x Haze Gel marine 12v 282Ah (100hour rate)
4 banks of 4 series/paralell= 48V 1128Ah
Regulator- Plasmatronics PL60 60Amp controller
Inverter- Selectronics SA-42 48V/240V 3600W continuous pure sine wave (10kw Overload)
Array faces North @ 32deg which is our latitude, I have designed the mounting system to be adjustable being able to drop them down to the pitch of the roof (16deg) for summer in a couple of months, I'm still in two minds as to whether I should raise them to 45deg for winter, see what happens with power output come May/June. so I'm hoping that I will only need to adjust the panels twice a year?????
below is a few pics of the solar array I finished yesterday.
More pic's as i go along. Word of warning- Have someone help you
I put all this up myself and I'm absolutly stuffed, those panels are bloody heavy at 29kgs each (2000mm x 1000mm)
System details
