I am still wondering how to go about buying used batteries. As far as pricing goes I stopped by my local scrap yard trying to buy a few but they refused to sell me any due to lead is toxic and acid is dangerous. So what I decided to do is put up flyers offering to pay other for scrap car and truck batteries for 0.14 cents a pound it is a little more than what local scrap yard is giving but I have no way to weigh a battery. So I was wondering if I could use group size to determine weigh so I am not ripping people off or me?
Solar panel companies really should label their panels better. Like something that says a 250W really only puts out 200W. See this is what made me so mad I got these panel and tested them and they put out exactly what they were marked on the back label 38.1 volts and 8.6 amps with no special treatment and it was a cloudy day they even read on the charge controller of 38 volts when the cc was not charging and pulled down to 36 volts with a 6,000 watt inverter pulling on them feeding my whole home that's with a electric stove, a 2 horse well pump, 4,500watt water heater, and everything else a 1,200 sq house has lights tv fridge deep freezer etcetera and it did that with no problem I was happy then one day in the middle of summer on the hottest day the system went nuts burning wires, disconnect, cc, battery bank and fuse up everything between the panels to the fuse right before the inverter was trash like there was a huge power spike or someone crossed the wires. Nominal peak power(Pmax) 250w with a fall off of 10% in the first 15 years is 225 watts at the end of 15 years it should be no lower than 225 watt for peak output and this is how the warranty reads this is why I am mad about the whole thing solar manufacturers should really think of rewrite their warranties if this is the true capability of their panel. I know it probably sounds like I am mad at you but I'm not it is just frustrating to think that a panel fell off 25 watts in the first I test the other panel I have had in the house today and it's at 24.4 volts by itself with no load. but when I did my loop test it put out over 9 amps. I still have not found out if a 1000 HID lamp would work for testing? And the new solenoid cc the guy gave me is acting up it is hot right now at 8:30 at night no sun and the inverter is off so the only power going to it is from the battery bank and I thought it was stuck in the off position again but I checked and it's not. for some reason when it is off the solenoid gets super hot which is probably what caused the last one to burn up. IDK sorry I got of on a rant I hope you all are well with all this isis junk going on and remember to be safe.
