So I have a small system I am attempting to power a small cabin with. I have wired the cabin with some normal 120v ac outlets and lights.
The cabin has a 200-amp breaker with some normal breakers, GFCs and Arc Fault breakers.
I am running the battery to a renogy 500w inverter, then I plugged in a cord I made from 12/2. Then ran the 12/2 black to where the SE cable would go in the breaker box, the neutral to the neutral bus bar and the ground to ground bar.
HOWEVER, only half of the circuits work. It's every other slot. I can re arrange the circuits and this consistently works. My voltage pen shows no voltage when they are in the bad slots on the breaker.
Do I need to pig tail the black from my 12/2 cable so that I have two cables coming into the servience entrance screws? I have to screws for grid power but only have one with a wire in it.
Note, this is to only test the system before I put up insulation and sheet rock.
Any help would be great.
