Just starting to set up a small solar system off grid at the cottage. The price of a 250w panel is barely more than a 100w panel. Proplem is if you are running a 12v inverter the 250w panel will not give you any more power than the 100w panel. What if you put two charge controllers in series so theoretically each would put out 12v at the maximum amp output then you could connect both outputs to your battery bank and get the full use of the 250 watts. Has anyone tried this or have any experience in it. Just trying to save a few bucks on panels and save some space and mounting hardware
Thanks
Thanks
