Hi,
I have the following: (2) Renogy 100w Monocrystalline Panels configured in series, 20A MPPT Charge Controller, 12 Volt 125 AH battery, and a 500w pure sign wave inverter. I wanted a small system that I could use to run a few lights, run a small fan and charge my electronics doing so from a green source. (I live in PA and our electricity is cheap and made from coal so a Grid tie system did not make financial sense to me). Now my problem: I am confused on grounding and the more I read the more confused I get... I connected the ground from the inverter to a separate ground rod that I installed. I wanted an isolated system but the more I read the more I believe this was a mistake. Is it possible to run a separate system in my house and make it safe? I would rather not remove the inverter from the system, but the more I read this forum the more I'm thinking the only way to be safe is to run only DC loads from the 12 volt battery. I have a smart powerstrip that is telling me I do not have a ground. So I was thinking I should bond the neutral to the ground but this seems to be a mistake since that should only be done once in a service area. So I added a GFCI plug after the inverter hoping that would make things safer. I could use some help. Thanks.
