so i am looking for the best way and cost effective way to mine in the sun with out power why not use solar i think it can work i am 28 years old and i want to try my luck at owning a mine and crush rocks so i found a rock crusher that will work its a 1hp motor and this is all specs i can find
so my question is i want to run this about 5hr to 8hrs aday if possible with out having to build something huge i will be in the mountains with direct sun light all day in Az so what can you guys come up with ? to help me out would not mind trying to build it so any help would rock thanks ok a little up date so this is what it looks like that is for sale http://www.ebay.com/itm/Rock-Crusher...item35ee519615 thats the link on ebay now i dont mind buying a dc motor that would work i just need best cost effective way
Name 1 HP Agricultural Farm Duty Motor
SKU 68288
Brand Smith + Jones
Amperage (amps) 13.1
Horsepower (hp) 1
Maximum speed (rpm) 1800 RPM
Quantity 1
Rigid base (y/n) Yes
Service factor 1.15
Shaft rotation direction CCW
Shipping Weight 34.10 lb.
found this would this work better than ac ? and can i run it from just the sun the whole thing is i have to keep around 1800 rpms
Technical Specs
ItemDC Permanent Magnet MotorMotor ApplicationVariable SpeedMotor DesignPermanent Magnet DCHP1Motor Enclosure DesignTotally Enclosed Fan-CooledNameplate RPM1800Voltage12VDCFull Load Amps80Full Load Torque35 lb.-in.Frame56CMotor Mounting TypeFace/BaseMotor Thermal ProtectionNoneInsulation ClassFBearingsBallMax. Ambient Temp.40 Degrees CRotationCCWLEOverall Length13-7/8"Length Less Shaft11-7/8"Body Dia.5-5/8"Shaft Dia.5/8"Shaft Length2-5/8"Base Mounting O.C.3" x 4-22/25"Face Mounting O.C.5-7/8"Brush TypeCarbonRPM Range1701-1800FeaturesRemovable BaseStandardsUL(E49747), CSA(E49747)
SKU 68288
Brand Smith + Jones
Horsepower (hp) 1
Quantity 1
Service factor 1.15
Technical Specs
