Portable generator with AGS (auto generator start)
  • hammick
    • Jul 2015
    • 368
    I will be installing a Conext 4048 inverter in my off grid garage. Eventually I will want to add a generator with AGS. The 4048 allows load sharing a bunch of other triggers to auto start the generator.
    I know most of the Kohler and Generac standby generators have AGS ability. Also the Honda EU700is fuel injected generator has AGS.
    My question does a generator like the Generac XP6500E have AGS?: http://gens.lccdn.com/generaccorpora...e.pdf?ext=.pdf
    If a generator has a carburetor how effective can AGS be? I'm assuming even the standby Kohler and Generacs have carburetors and probably don't work in freezing temps?
    I tried to research AGS and portable generators but really not any info.
    Conext XW5548
    Conext MPPT60-150
  • hammick
    • Jul 2015
    • 368
    OK so I don't think it is possible to auto start just any electric start portable generator. It needs to have AGS circuitry.
    Has anybody installed an second key switch for their generator? I would like to do this. The switch would need to be close enough that I can hear when the generator starts (or doesn't start). Also it could only be used if the generator was warm (mine has a manual choke).
    I guess I need to figure out if the key switch carries current or just toggles a starter relay. If it carries current the wire size would probably be prohibitive so I would need to use a relay.
    My generator is a Tsurumi tpg-7000h-dxe that has the Honda GX390 engine.
    Conext XW5548
    Conext MPPT60-150
