Hi,
New here.
Just started to build a new project for my shed, nothing fancy or big, I'm using a BP Solar 40w panel, MorningStar ProStar 15 and a small 9-18amp sealed lead acid battery (not got the battery yet)
I'm starting from scratch and want some advise on wire and fuses / breakers.
My system is basically going to run LED lights in the shed, 5v USB charger and a small 12v dc pond pump. I'm going to run direct from the ProStar load output, I don't see myself with an inverter at this stage (battery maybe too small for one anyway) but it's possible I may use one latter (if I change out the battery)
I'm location in Toronto (after moving from the UK) for some reason finding anywhere local that has solar stuff is not easy.
Can anyone recommend a good reliable online source for solar stuff. Locally everything is so costly.
My question are I was going to get some 10awg wire and use that for the whole system, to connect everything.
I want to run fuses on all the positive lines and maybe use breakers for the battery feed and panel feed so they can double up as disconnects.
Does this sound like a good idea?
As it's not a large system I was thinking of using 3-5 amp midnite solar breakers, but the fuses I'm getting conflicting info online, I was going to use car ratted blade fuses but that seems like a bad idea, so I was thinking glass quick blow fuses again at 3-5 amps
Any advise would be great
Thanks
New here.
Thanks
