Mismatched panels on 2 strings
  • Raul
    • 258
    I got 4 panels 300+250 and 285+260w . Could I use solar edge optimisers on each panel then parallel the 2 strings into a mppt charge controler . Would this multi tracking work or help to make use of this panels ?
    On each string there is similar voltage and amp within 5% or less. I would expect some loos but would it work?
    Thank you in advance.
    • 3802
    Yes you can mix any solar modules with solarEdge but the optimizers are MPPT optimizers so you would use them with a solar edge inverter not a charge controller with MPPT built in. Also solarEdge requires at least 8 ( really minimum of 6) optimizers per string to operate, so you would need at least two more, and better with 4 more modules / optimizers.
    • Raul
      • 258
      Thank you for your input. I anderstand that optimisers are designed for the specific inverter on grid application. I was hoping to use it for a off grid charging a battery bank .
      If I use this panels with a mppt charger would it still work ? They not off each other by much and some loss would be expected.
