Hello - I have recently purchased a Suoer ST-G1230 12v / 24v Charge controller in Pakistan (perhaps not the best charge controller). When I plugged in the battery, panel and a small load of a 10 watt bulb and made some changes to the power mode from on/off to timed off, the charge controller went into debug mode (17) and refuses to come out of it. I have powered it off and on many times, kept the mode button pressed for many minutes (as recommended) but nothing happens. The charge controller is lighting the bulb but just can't bring it out of debug mode. I was hoping that someone may have some tips on how to sure this. Many thanks in advance.
Frozen Solar Charge Controller - Debug Mode
Did you connect the CC to the battery before connecting it to the PV?Hello - I have recently purchased a Suoer ST-G1230 12v / 24v Charge controller in Pakistan (perhaps not the best charge controller). When I plugged in the battery, panel and a small load of a 10 watt bulb and made some changes to the power mode from on/off to timed off, the charge controller went into debug mode (17) and refuses to come out of it. I have powered it off and on many times, kept the mode button pressed for many minutes (as recommended) but nothing happens. The charge controller is lighting the bulb but just can't bring it out of debug mode. I was hoping that someone may have some tips on how to sure this. Many thanks in advance.
Most CCs will not boot correctly if the panel is connected before the battery.SunnyBoy 3000 US, 18 BP Solar 175B panels. -
At the moment I'm running the charge controller without the panel attached to see if I can get it out of debug mode. I did try it earlier with everything connected in the order that they should be but that's when the problem started.Comment
Sadly, most charge controllers with LOAD outputs, have severe limits on how much power the LOAD terminals can supply. Usually less than 1 amp. So it's possible that the bulb damaged the controller.
Try unplugging everything for an hour, then short the output (batt) terminals, short the PV terminals for 5 min (to bleed down any capacitor charge internally) then remove the shorts and connect ONLY to the Battery terminals, and try the reboot/recovery process. Don't connect the solar terminals or the load, just the battery.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
It didn't work I'm afraid. Tried everything but it looks like I may have a sick charge controller.Sadly, most charge controllers with LOAD outputs, have severe limits on how much power the LOAD terminals can supply. Usually less than 1 amp. So it's possible that the bulb damaged the controller.
Try unplugging everything for an hour, then short the output (batt) terminals, short the PV terminals for 5 min (to bleed down any capacitor charge internally) then remove the shorts and connect ONLY to the Battery terminals, and try the reboot/recovery process. Don't connect the solar terminals or the load, just the battery.Comment
