My 24 Aquion AHI batteries
A cycle is any discharge followed by recharge.[ATTACH]7066[/ATTACH]
According to Conext ComBox, 1000Ah = 1 cycle. Aquions have a 51Ah capacity, since there are 24 stacks in our system, then we have 1224Ah total capacity. We have removed 34071 Ah from our battery bank which actually calculates out to 28 cycles. Is this the correct way to figure out cycles? Maybe not, they're Aquions
BattMon61415.jpgAloha,
Just had my installer check how our system is doing, the one doing the Balken Estate on the Big Island. Everything has been working GREAT. We are running the 1st Gen and all seems well. Haven't had them down past 60% SOC for a while, since we have Full Charge most everyday. Have had system running for 7 months now and batteries have cycled 31 times. This adds up to around 4 1/2 cycles per month. Let's just say (hypothetically) 6000 cycles @ 50% DOD. Our system cycles 54 times per year. Battery lasts 100 years
Great to hear you are getting good results from that battery. I appreciate getting your status updates.Aloha,
Aloha,They've presumably been testing the chemistry for several years. They're claiming 3000 (100% DOD) to 6000 (50% DOD) cycle life. At the 5 hour current rate, would take 2*3000*5/(24*365)=3.4 years, which they haven't had enough time to do on each version. So they're either testing at greater than the 5 hour rate (which I doubt) or testing on individual cells (which should take a lot less time to charge/discharge) and estimating the system performance.
From what I can tell, the second version had lower internal resistance and the third version has a higher current limit.
Looks like a good technology to wait a few years and see what real-world performance reveals and let the price come down.
Anything energy company Bill Gates invest in goes to chit guaranteed.There are two investors I watch to know what not to invest in.
Bill Gates and Willy Nelson.Leave a comment:
As Sunking mentioned, they are up to 3 product changes in a year and the voltage range has changed 4 times. It smells of capacity doping (a wider range to get more capacity). At best, they realized that no inverter will work with a wide range and "made up" one to make it look like it works with stuff on the market. It is probably a mixture of both. Regardless, it adds up to them still figuring out what the battery does.There are several threads in this forum discussing the technical aspects of these batteries.
They are tolerant to freezing, you would not destroy them. However, like most batteries, they have a higher capacity at warmer temperatures, so it would benefit you to insulate the battery box in freezing weather.
The newer version that is available this summer has a 20A fuse instead of the existing 15A fuse, so they are making improvements in the charging rates available. They also have increased the voltage range, so the new minimum voltage is 40V instead of 30V, lining up better with most inverters.
Their install manual includes recommended settings for most major charge controller models.
How would going from a 20A fuse instead of a 15A fuse improve their charge rates? Fusing is for protecting things from being damaged by heat. Don't they offer a version without a fuse anyway? Did they change the connectors and jumper wires to handle a greater amount of heat and current?Leave a comment:
There are several threads in this forum discussing the technical aspects of these batteries.It's a shame that you have one of the most innovative battery systems ever offered and
no one seems to have asked any technical questions.
OffGridHI - can you tell us a little more about performance compared to the batteries
you had before ? What are the charge / discharge rates ? Are you using the same charge
controller as before ? And did Aquion have any recommendations about charge controllers -
seems to be that the behavior of these batteries has to differ in some significant ways
from what has been used before ?
I am very interested in these - contacted Aquion direct last year but have not pulled the
trigger yet - one of my main concerns being that I live in an area of actual WINTER weather
and what would happen when / if the temps in my battery storage room dropped below freezing.
I'm assuming that this would destroy the Aquions.
Looking forward to any first hand info you can give us.
Thanks.
Their install manual includes recommended settings for most major charge controller models.Leave a comment:
All I need to know is just what fact or facts in going on 4 years
are Lies so that I can correct them.
Have I run too many posts over the years?
The 3rd AHI Generation isn't here yet. They hope to be there by the
end of this year.
There are only 2.
Did they never change Lead Acid as they went along ?
Do Trojans stay the same ?
AHI claims to be 8 year old technology as of the 4/21/15
Press Release about The Cradle to Cradle deal.
I'm into things bigger than batteries.
Old Bill has no dog in dis hunt.
Relax. You'll live a lot longer.
Google follows me around the Internet like a puppy dog and the last
thing that I want is to make them look bad.
Bill BlakeLeave a comment:
They've presumably been testing the chemistry for several years. They're claiming 3000 (100% DOD) to 6000 (50% DOD) cycle life. At the 5 hour current rate, would take 2*3000*5/(24*365)=3.4 years, which they haven't had enough time to do on each version. So they're either testing at greater than the 5 hour rate (which I doubt) or testing on individual cells (which should take a lot less time to charge/discharge) and estimating the system performance.Bill why is it a battery company only 4 years old, with less than 1 year of sales under their belt are on their 3rd product revision? How can a battery company with less than 1 year worth of product claim 10,000 cycle life and have to already have 3 revisions of their product line? What was wrong with the fist two revisions?
Looks like a good technology to wait a few years and see what real-world performance reveals and let the price come down.Leave a comment:
Old Bill is spreading it as per usual - all chatter with no substanceBill why is it a battery company only 4 years old, with less than 1 year of sales under their belt are on their 3rd product revision? How can a battery company with less than 1 year worth of product claim 10,000 cycle life and have to already have 3 revisions of their product line? What was wrong with the fist two revisions?
Please tell us Ole Bill as inquiring minds want to know why Shinola smells like **** and looks like a Rat.Leave a comment:
Bill why is it a battery company only 4 years old, with less than 1 year of sales under their belt are on their 3rd product revision? How can a battery company with less than 1 year worth of product claim 10,000 cycle life and have to already have 3 revisions of their product line? What was wrong with the fist two revisions?However Sunking it was only this week on 4/21/15 that it was proclaimed
Throughout The Land that the Aquion Energy AHI Batteries are the first ever
to become:
'Cradle to Cradle Certified'.
This as of The 2nd AHI Generation.
You have been elegantly stepping and stomping on the
First AHI Battery Generation.
Old Bill has been meekly asking around a bit about the next
3rd AHI Generation coming up.
Bill Blake
to become:
