It is posible to connect 2 different batteries banks to a single power inverter? if so what do i need? Thanks for any help
HELP PLEASE!!! (connecting 2 different battery banks to a power inverter)
Yes, it is possible. Generally, not desirable.
Tell us more of what you are trying to do.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I want to connect my actual battery bank to a new battery bank using 1 single power inverter because I don't want to mix batteries brands. Each battery bank will have their own battery charger and solar panels. Thanks for any help.Comment
Once you connect the two bank of batteries to the same inverter, the Batteries are mixed no matter you like or not. Unless you use disconnect switch and use one bank of batteries at a time and not the same tme.Comment
