Seeking your MPPT CC Advice - Off Grid
    Both the Morningstar MSView sw and the Midnight Local App allow you to limit the battery amps via software in the MPPT controller
    I know the Morningstar MPPT 60 has a web HTTP server built in, and is very easy to monitor and skip the optional $100 meter.
    I dont know if the Midnight Kid is controllable via Local App or if it allows battery amp limit.
    • mschulz
      • Jan 2014
      • 175
      Hey Mike, Do you have to have an internet connection to make those changes or just a PC connected to them. I have been looking into them but have not pulled the trigger as I have no internet at the site I need them installed.
      Thanks for any info on this.
        The Morningstar needs a RS232 cable to the PC (using a serial port to USB adapter works for me) to reprogram it. I carry a laptop out to it when I need to tweak it
        To monitor, it's just a web address & Browser.
        Midnight, the Local App and a web address, gives you monitor. For control, you need the ser # too.
        I have both units plugged into a wireless router, and monitor from there with a browser. (Same with the XW ComBox)
          RS-232? Ancient technology....
          • TriggerGolf
            • Feb 2015
            • 7
            Mike - how dare you mention a connector that the KING would disapprove. King - would a CC with USB 3.0 be OK? Or is your highness a blue tooth only guy?
            Originally posted by Amy@altE
            Wow, you got me on that one, I had never heard of a 50 cell module. I used to sell 54 cell modules, but never 50. I did confirm the specs, it is right. BP made very nice panels, but those are probably very old.
            http://www.midnitesolar.com/sizingTool_kid/index.php.
            Queen - do you think I should avoid the panels because they are old?
            This was good feedback & advice.
            Originally posted by jony101
            Below you can see the box I made it also has a 99 volt LED meter to display the solar panel voltage. The mppt controller is to the right with very small LCD screen. My recommendation is get a LED display.
            Very cool.
            Charge current is determined and controlled by panel wattage. There is a couple of controllers out there that will allow you to limit current to some point but completely defeats the purpose. If you want to limit the current you select the right panel wattage, and that is real easy to determine Charge Current x Nominal Battery voltage Panel Wattage. So 10 amps x 12 volts = 120 watts. 5th grade math.
            But that has nothing to do with what you want to do. At this point you have no clue what is needed because you failed to take the first most important step. You did not determine your daily Watt Hour requirement Until you do that you are just wishing and throwing money away. Once you know what the requirement is, then you design a system to meet the requirements. Fail to do that and 1 of 3 things happen.
            King - do you guys have a FAQ? I received a couple different answers in this post. Perhaps you guys should group together and create a matrix of different panels, panel counts, CC & battery capacities. Can the solar royalty come together to help?
            -SolarPeasant
              I am just poking fun at Mike. He knows me well enough to know that.
              • LucMan
                • Jul 2010
                • 628
                Anything bigger than a 36 cell module with a PWM charge controller is throwing power (and money) away. So you'll still need an MPPT with them. I'd still go with the Kid, but you could probably use 1 for the 2 panels, double check with their sizing tool, http://www.midnitesolar.com/sizingTool_kid/index.php.
                The SX 3200 panels are 6-7 years old, I have 26 installed on my house. BP is out of the solar business, so no warranty.
                For $100 I would snap them up in case I ever have one fail.
                • Amy@altE
                  • 1023
                  Yah, BP made some quality products. If it is worth the risk knowing you will not have a warranty, $.50 a watt for BP is a killer deal. Again, watch out for shipping costs if they aren't local, that can mess up the whole deal.
                  Solar Queen
                  altE Store
                  • Bucho
                    • Dec 2013
                    • 167
                    Originally posted by Wy_White_Wolf
                    40A into a 120Ah lead acid battery is too high of a charge rate and will destroy it. That is a rate of C/3 (120/40). You need to try and keep that rate between C/8 and C/12 (15A to 10A) with C/10 usually being about ideal.
                    WWW
                    Well he's using a marine battery not a deep cycle, so his battery might be able to take that charging rate, no?
                    • Wy_White_Wolf
                      • Oct 2011
                      • 1179
                      No. It's still a lead acid battery. If he was using am AGM battery it could possibly take that high of charge rate.
                      WWW
                      • Bucho
                        • Dec 2013
                        • 167
                        WWW
                        In that case would you explain Sunking's comment here:
                        Originally posted by http://www.solarpaneltalk.com/showthread.php?9093-WTF-Is-the-Deal-With-Batteries-Tutorial
                        * Hybrid Batteries are useful in RE applications. Like the name implies they are a cross between SLI and True Deep Cycle batteries. They have fewer thicker plates than SLI batteries to obtain some deep cycle capability, and lower internal resistance for decent high current charge/discharge rates. However the plate s are not as thick and heavy as True Deep Cycle batteries. So what you get is trade-offs.
                        They can deliver/take higher discharge/charge currents than True Deep Cycle, but not as much as SLI batteries. On the other hand they do not have the high number of cycles as True Deep Cycle batteries. For the FLA types you still have the lower limit charge rates of C/12 to prevent stratification, but on the charge/discharge side of FLA hybrids you can go as high as C/4, and some cases C/2.
                        AGM hybrids are extremely expensive and resemble SLI batteries more than True Deep Cycle. They are used in UPS systems, Golf Carts, Floor machines, and Electric vehicles where moderate amounts of high current is required with som efair cycle life. Hybrid AGM's have very low resistance and can take a C/1 or higher charge\discharge rates. The downfall of them they only have 300 to 500 cycles in them. Hybrids are best used in systems that are infrequently used with high discharge rates like Emergency power and UPS systems.
                        • Living Large
                          • 910
                          Very cool.
                          -SolarPeasant
                          I wouldn't put any stock in titles, but Amy and Dereck are very knowledgeable and have given me outstanding advice on this board, as many others have as well. I just hang in there and keep posting until I find out what I need to know, and try not to let myself have any knee-jerk reactions. It's the internet, you know.
                          I find the moniker "Solar Queen" rather endearing. Watch the AltE videos - you'll think you died and went to heaven.
                          • Amy@altE
                            • 1023
                            Living Large, you'll make me blush. I used to be the "Solar Thermal Queen", SHW was my specialty, but when I got promoted last year I became queen of everything (isn't that a song?)
                            Solar Queen
                            altE Store
                              • 15071
                              My bride has already claimed Queen Of The Universe, so that position is taken.
                              • Amy@altE
                                • 1023
                                I bow to my superior...
                                Solar Queen
                                altE Store
